enable learning port
enable learning {drop-packets} ports [all | port_list]
Description
Enables MAC address learning on one or more ports.
Syntax Description
drop-packets Forwards EDP packets, and drops all unicast, multicast, and broadcast packets from a source address not in the FDB. No further processing occurs for dropped packets.
all Specifies all ports.
port_list Specifies one or more ports or slots and ports.
Default
Enabled.
Usage Guidelines
Use this command to enable MAC address learning on one or more ports.
The following example enables MAC address learning on ports 7 and 8 on a switch:
enable learning ports 7-8
Platform Availability
